Browse Forums Landscape & Garden Design Re: Lawn thoughts Empire Zoysia - Help? Concerns? 21Oct 25, 2016 6:14 pm I will post some pics this arvo for you guys. I was actually looking for info regarding the height of my lawn. My old man thinks it's too spongy. I will post a pic and look forward to your responses. I am in Perth (Kingsley). Re: Lawn thoughts Empire Zoysia - Help? Concerns? 22Oct 25, 2016 8:09 pm http://i63.photobucket.com/albums/h125/subwayboy/20161025__zpsdg5w6w52.jpg http://i63.photobucket.com/albums/h125/subwayboy/3_zpsijsfujc1.jpg Here is the lawn as it is today. Have just turned the sprinklers back on. I was concerned that it needed de thatching. Any advice on that? Re: Lawn thoughts Empire Zoysia - Help? Concerns? 23Oct 26, 2016 9:49 pm Whilst the grass doesn't look 100% I'd definitely say it's settled and taken well now. I've read that zoysia doesn't suffer from thatch ( or rather low thatch ) as it's a different grass to buffalo or kikuyu. Rather, It's spread is through underground runners and deep roots. If your concerned about it being spongy, try a shallow top dressing of soil... Being in Perth, I'd suggest a fine organic mix rather than more sand. I certainly wouldn't be raking the hell out of it as regular mowing will remove most of the dry dead material caught in the root zone. Besides, it's probably a good thing that the grass has a little protection over the warm dry weather anyway. Have you tested the pH of the soil? a simple pH imbalance can make the most bullet proof weeds even struggle. Depending on the pH, you can incorporate your organic buffers whilst you top dress. Re: Lawn thoughts Empire Zoysia - Help? Concerns? 25Oct 27, 2016 8:04 pm For less than $20 you can get a pH test kit for soil from bunnings. It's good to check as pH can have massive effects on plants. Re: Lawn thoughts Empire Zoysia - Help? Concerns? 26Nov 01, 2016 10:51 am SteveMc For less than $20 you can get a pH test kit for soil from bunnings. It's good to check as pH can have massive effects on plants. Can you provide any thoughts on the height? Should it be cut lower? Re: Lawn thoughts Empire Zoysia - Help? Concerns? 27Nov 01, 2016 11:08 am According to ozbreed who culture the zoysia breeds, and their documented care approach is to water only when needed, fertilise sparingly, and mow infrequently. All of which suggest that the grass need not be dethatched. Specifically they mention for a low maintenance approach, leave the grass to 75mm-90mm, then cut to 40-50mm. However, I'd definitely look into pros and cons of the watering and fertilising regime for this grass via the web site. Ultimately you may choose to do more, to get the manicured effect that you see on golf courses. Empireturf.com.au > care & installation. Re: Lawn thoughts Empire Zoysia - Help? Concerns? 28Nov 01, 2016 5:35 pm SteveMc According to ozbreed who culture the zoysia breeds, and their documented care approach is to water only when needed, fertilise sparingly, and mow infrequently. All of which suggest that the grass need not be dethatched. Specifically they mention for a low maintenance approach, leave the grass to 75mm-90mm, then cut to 40-50mm. However, I'd definitely look into pros and cons of the watering and fertilising regime for this grass via the web site. Ultimately you may choose to do more, to get the manicured effect that you see on golf courses. Empireturf.com.au > care & installation. Cheers!! Thanks for all replies. I just noticed now the pictures I added to post right on top of page were wrong. I attached pictures showing "current" and my "suggested" floor… 9 11912 Regardless of wall hung toilet or floor pan toilet your feet will be right on drain, seems to me the waste should not be in that location given the design. Also are you… 6 4620 Were struck with: Colorbond Ironstone Grey roof and cream windows. What color should we render and paint the garage door to tone down the cream windows? Farm House, will… 0 15483 |
