Browse Forums Landscape & Garden Design 1 Jan 15, 2016 11:25 am Hi Guys, Laywed 200 squares of Empire Zoysia around the end of december. Mostly it is looking great. My watering concession has just ended and I am now on the twice a week Perth standard. I did soil prep as fu's instructions. I have concerns about some browning of the lawn, same part looks dead, while the most part it is lush and green. Any advice? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Lawn thoughts Empire Zoysia - Help? Concerns? 3Jan 15, 2016 7:49 pm That lawn is looking nice. There will always be some die back in turf a month after laying, but overall the turf has taken well. I wouldn't worry about the edges as the rest of the grass will spread and cover these areas. The rest of the turf is well and truly established so relax and let it run out a little over the hot months as the lawn will take a hit when you cut it. Take the cutter height up another two notches if you must cut it. Overall i wouldn't be concerned. using Tapatalk Re: Lawn thoughts Empire Zoysia - Help? Concerns? 4Jan 16, 2016 7:24 pm How are you going with your lawn? Also in Perth, we laid 30sqm at the beginning of October also according to Fu Manchu thread info (except used soil solver clay plus instead of the bentonite etc), and after a good start it has gone really bad and looks like it is all going to die . Have had the Soil Solver guy have a look, and so far being fobbed off by the turf supplier and they haven't been to see it. In desperation have aerated with a garden fork, applying soil wetter twice in the last month, seasol and mollasess weekly, and another dose of Bactivate. Twice weekly deep watering on the retic, and most days hand watering as well. Any ideas? What could be wrong and how or who can I get to fix it before it is too late.... 20 days after laying and how it looked until mid December Just when it started to look bad 14th December 6th January and a week later 15th Jan Re: Lawn thoughts Empire Zoysia - Help? Concerns? 6Jan 21, 2016 12:06 pm SteveMc That lawn is looking nice. There will always be some die back in turf a month after laying, but overall the turf has taken well. I wouldn't worry about the edges as the rest of the grass will spread and cover these areas. The rest of the turf is well and truly established so relax and let it run out a little over the hot months as the lawn will take a hit when you cut it. Take the cutter height up another two notches if you must cut it. Overall i wouldn't be concerned. using Tapatalk What does run in mean? Some more dead/yellow/dry patches have appeared not on the edges but in the middle of my lawn? Still no concern? The majority is still green. Re: Lawn thoughts Empire Zoysia - Help? Concerns? 7Jan 21, 2016 2:56 pm SteveMc What does run in mean? Some more dead/yellow/dry patches have appeared not on the edges but in the middle of my lawn? Still no concern? The majority is still green. The grass just needs to grow out. Don't be concerned at this early stage with mowing. If you let it clump and spread it will colonize the dead zones. Keep in mind that council strips and parks use this grass and rarely water or tend to these areas apart from the first couple of weeks. Zoysia should thrive once left to strike and develop in the top soil. As you know already, the majority is going well, so don't be alarmed with the dead zones. Zoysia is also quite resilient to pests and disease so it is just some areas of turf that might have been cut or damaged between cutting, transport and laying. My tip... Relax using Tapatalk Re: Lawn thoughts Empire Zoysia - Help? Concerns? 8Jan 22, 2016 12:36 pm SteveMc SteveMc What does run in mean? Some more dead/yellow/dry patches have appeared not on the edges but in the middle of my lawn? Still no concern? The majority is still green. The grass just needs to grow out. Don't be concerned at this early stage with mowing. If you let it clump and spread it will colonize the dead zones. Keep in mind that council strips and parks use this grass and rarely water or tend to these areas apart from the first couple of weeks. Zoysia should thrive once left to strike and develop in the top soil. As you know already, the majority is going well, so don't be alarmed with the dead zones. Zoysia is also quite resilient to pests and disease so it is just some areas of turf that might have been cut or damaged between cutting, transport and laying. My tip... Relax using Tapatalk here are photos of the concerning bits. I must say your info has put my mind at ease. Re: Lawn thoughts Empire Zoysia - Help? Concerns? 10Feb 10, 2016 7:02 pm I have this with my Empire Zoysia as well. I'd recommend getting a lawn grub and lawn beetle spray bottle from bunnings/masters and doing your lawn in that first to rule out grubs. I found a single lawn beetle dead after I did my lawn. Secondly, to recover, I found watering helped but not much. Try some fertilizer. I again used the hose in stuff from bunnings/masters and it worked OK. Grass is growing back, but slowly. I also found that it occurs where the grass touches concrete. I can think of two reason why it does it around the edge of my house (I have an exposed terminte barrier, basically a concrete strip) - Chemicals leaching from the concrete. - Concrete gets hot, heat kills the grass. In winter it is less of a problem, but in summer I need to water it a lot to prevent it dying. Also tried a wetting agent to see if I could keep the water in the ground longer, but it didnt help. Interested if anyone else has any remedies. My Noosa 23 Build - viewtopic.php?f=31&t=72782 Re: Lawn thoughts Empire Zoysia - Help? Concerns? 11Feb 15, 2016 11:14 am I have the opposite problem to you guys. My zoysia is growing like mad since laying it down 4 months ago. Im cutting it back every weekend now, 200m2 worth. I dont bother watering it anymore, natural rain once every 2 weeks seem to keep it alive. Maybe you guys are over caring it? My annoyance is that this grass produce alot of seed flowers I think called stolons? So lawn only looks good for about a week then it looks furry with all the stolons growing through. Anybody know how to reduce the growth of stolons? Re: Lawn thoughts Empire Zoysia - Help? Concerns? 12Feb 15, 2016 12:21 pm Hmm, mine is growing like mad as well. Also mowing once a week. If I get a week or rain, then it can grow 10cm in the week. I used to get the stolons growing, generally around the beginning of spring. Haven't seen them at all over summer. Generally with weekly trimming I guess they don't have time to grow. I don't think you can stop them, unless you mow more often. During winter though, the grass just stops going upwards. I mow once every 1-2 months. My Noosa 23 Build - viewtopic.php?f=31&t=72782 Re: Lawn thoughts Empire Zoysia - Help? Concerns? 13Feb 15, 2016 12:31 pm Can you tell me how old is your lawn? I think because mine is recent, it sprouts more stolons until it maybe a years time then it settles. Heres hoping anyway. Re: Lawn thoughts Empire Zoysia - Help? Concerns? 14Feb 16, 2016 12:35 pm BrandonZoe Can you tell me how old is your lawn? I think because mine is recent, it sprouts more stolons until it maybe a years time then it settles. Heres hoping anyway. Just under 1yr old. Planted late march in 2015. Around October it seeded for a few weeks. Hasn't done it again since. My Noosa 23 Build - viewtopic.php?f=31&t=72782 Re: Lawn thoughts Empire Zoysia - Help? Concerns? 15Feb 17, 2016 12:18 pm The yellow patches, go with watering. And come back with the heat. I have mowed it twice, and as luck would have it both times it was 40 degrees the next day, I think that has knocked it around. I may reduce watering a touch as it is growing really fast. Other than the issues above we have been really happy with the lawn, the feel, the colour etc. Hoping it will keep its colour over the winter months. I'm not keen on using the lawn beetle spray, just going to keep the seasol, molasses etc process going. Re: Lawn thoughts Empire Zoysia - Help? Concerns? 16Mar 11, 2016 10:25 pm My EZ grass, laid early Nov has same issues. I get a bit of die back in areas when we were having those consecutive 35 degree days, but bounces back in time. A few patchy areas too. I found it recovered quicker the less frequently I looked at it. Re: Lawn thoughts Empire Zoysia - Help? Concerns? 17Mar 29, 2016 2:00 pm How long should this lawn be? I am at the 4th longest setting on my Victa, started at the highest and am working backwards (lower) after a lawn contractor told me my lawn was way to long. It is maybe around 2-3 inches. He thinks I should gradually work my way to the lowest setting on my victa rotary mower? I think this will be too low? Re: Lawn thoughts Empire Zoysia - Help? Concerns? 20Oct 19, 2016 4:10 pm subwayJ How long should this lawn be? I am at the 4th longest setting on my Victa, started at the highest and am working backwards (lower) after a lawn contractor told me my lawn was way to long. It is maybe around 2-3 inches. He thinks I should gradually work my way to the lowest setting on my victa rotary mower? I think this will be too low? I doubt you are doing anything but protect the grass by leaving it a bit higher as this grass doesn't thatch like kikuyu or buffalo does if you let it go. That is, assuming you are not watering regularly (only by natural rainfall) and in a warmer climate area. Hows the lawn looking now? I hear that over watering and fertilising can make the Zoysia actually go nuts with stolons. I'd be interested to know how the cutting height and cutting regime has worked out for you over nearly a year now.. Also, what area are most of you from? Information about this species suggest that it is a warm climate grass that is most suitable north of Sydney (best suited to Queensland). Thanks for all replies. I just noticed now the pictures I added to post right on top of page were wrong. I attached pictures showing "current" and my "suggested" floor… 9 14651 Regardless of wall hung toilet or floor pan toilet your feet will be right on drain, seems to me the waste should not be in that location given the design. Also are you… 6 7048 Were struck with: Colorbond Ironstone Grey roof and cream windows. What color should we render and paint the garage door to tone down the cream windows? Farm House, will… 0 27355 |
