Browse Forums Landscape & Garden Design 1 Dec 10, 2015 7:49 pm Hi, we moved into our first home in August, we built with Simonds. We have a 19m X 5m backyard. It is level at one side then slopes to around an 800mm fall in the corner at the other side. Along the back fence we have a 2m easement. We have no idea what to do with the yard as we would like a deck, a small dog yard which would have my rotary clothesline in it and room for our daughter to play. Should we just build a retaining wall along the fence and level out the yard?? Any ideas would be GREATLY appreciated. You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17168 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16150 Thanks - yea sounds like I need to submit build over easement application....ugh guess I better start finding someone who can do the engineering drawings 3 3386 |
