Browse Forums Landscape & Garden Design Re: "Good Neighbour" fencing brisbane - cost 2Oct 31, 2015 6:43 pm No but I'm keen to know also! Building a modified Simonds Palisade in Brentwood Forest. View my build thread here: viewtopic.php?t=76776 Re: "Good Neighbour" fencing brisbane - cost 4Nov 17, 2015 8:27 pm We've been quoted $89 even though it's installed on fins without holes to be dug, because the fins aren't standard distance apart. Does that sound a bit off to anyone? Building a modified Simonds Palisade in Brentwood Forest. View my build thread here: viewtopic.php?t=76776 Re: "Good Neighbour" fencing brisbane - cost 6Nov 17, 2015 9:42 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi Travis, not sure if you can see the posts/fins on the retaining wall in this pic? Not sure on the distance maybe 1.5m apart? Building a modified Simonds Palisade in Brentwood Forest. View my build thread here: viewtopic.php?t=76776 Re: "Good Neighbour" fencing brisbane - cost 7Nov 17, 2015 10:50 pm Yeah gotcha. Basically you would normally have 2.4m bays (and 3000 is too wide) so you're going to be using double the posts. You will need at least 2, probably 3 bolts per post. I don't think $89/ml is outrageous depending on what kind of pailing solution you're going with. Re: "Good Neighbour" fencing brisbane - cost 8Dec 05, 2015 7:22 am travisaus Yeah gotcha. Basically you would normally have 2.4m bays (and 3000 is too wide) so you're going to be using double the posts. You will need at least 2, probably 3 bolts per post. I don't think $89/ml is outrageous depending on what kind of pailing solution you're going with. Spot on Give "Holt Surveying" they are based around Eight Mile Plains 3 11257 Hello Josh, This is Irving from PRIMA, we are a manufacturer of the staircase, railings, kitchen cabinets, windows, doors from China. If you have requirement to purchase… 0 5777 Hi, does anyone have a clue how the Brisbane Development website work in terms of how uptodate the dates on it are (developmenti.brisbane.qld.gov.au). I transfered… 0 4810 |
