Retaining Wall - Timber - any concerns?
Firstly may I compliment you on your photo mark up and sketch.
There should be no issues with Steel post and timber rails
I've calculated the height as roughly .90m approx. from the brick coursing
Rails are generally 2.40m in length and require H4 treatment
use 100UC15 Galv posts embedded 1.20m into pile footings in the ground
Being a driveway you may want to consider drainage etc
Let me know (PM) if you require further details
HTH
9
Thanks for all replies. I just noticed now the pictures I added to post right on top of page were wrong. I attached pictures showing "current" and my "suggested" floor…
5/12/2023
6
Regardless of wall hung toilet or floor pan toilet your feet will be right on drain, seems to me the waste should not be in that location given the design. Also are you…
18/12/2023
1
looks ok to me, round logs retaining walls are better than sleeper walls, more even preservative treatment and stronger since they include the whole tree and not just part…
