Browse Forums Landscape & Garden Design 1 Sep 03, 2015 1:32 pm Hi, I am planning on doing my own retic. Although I have a question regarding wiring the master solenoid valve. So the master solenoid valve will be at the water mains. The other solenoids will be in a separate location further away from the master solenoid valve. My question is can should all of these valves be connected with the same wire? or can I have a the master valve connected to the controller with a single core wire and have all the other solenoids connected to the controller using a separate multicore wire? Another question is, I am planning to use irritrol 205 solenoid valves for each stations. Can I use another irritrol 205 valve as the master valve? Any help would be greatly appreciated. Good luck with it. I don't know what the cost of a nice bidet seat with a 25mm air gap will be but you are obviously deducting the cost of a RPZ valve and its… 9 6985 First time building 2 storey home, is under construction (in Framing stage) in NSW. I have 3 toilets and need bidet spray in… 0 16861 Thank you so much. This has been very helpful. We definitely wish to settle and get these people out of our life. They are trying to charge us interest on late… 7 14280 |
