Browse Forums Landscape & Garden Design 1 Apr 16, 2015 6:56 pm Hello, I recently transplanted a row of hedges from my back yard to the front. Out of 14 hedges, around 9 withered and died. I removed them and tried again by transplanting a further 9 from the back to the front about 2 weeks ago. Once again, those hedges are showing signs that they are not doing well! I have leaves that are turning yellow, hedges beginning to dry up and show the same signs of imminent death as the last ones! I have watered and fertilised with seasol. Hopefully the photos show the hedges that are losing colour compared to the green ones that are thriving in the same soil. I don't know what else to do! HELP! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9074 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28813 I brought terry road box hill in June 2022 House was meant to be completed Nov 2023 That did not happen I had to chase them so much to the land Registration and… 0 2511 |
