Browse Forums Landscape & Garden Design 1 Mar 27, 2015 4:34 pm I am looking at installing a rainwater tank to run my irrigation from, however I would like some advice on how to make the water flow into the tank. I have somewhere in the vicinity of 8-10 down pipes around the house and would like to redirect the flow from these into the tank for the best capture of water. What is the best way of doing this? Follow my build here: viewtopic.php?f=31&t=74975 Re: Redirecting gutter flow to rainwater tank 2Mar 29, 2015 9:48 am You have to either divert the downpipes along walls or divert the pipepipes to a wet system. Wet systems are trouble and there are threads in Eco Living that discuss this. The tank overflow also needs to exceed the inflow capacity so that the tank doesn't over top during heavy rain. Have a look at the Supadiverta (one of my inventions), its use has numerous advantages when dealing with situations like the one you describe. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. 18 90425 DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31266 Grate, thank you! RexChan if thats the reason i could sleep well without thinking about additional cost. But 1st i'll need to read about NRV cleaning/replaing stuff. I… 7 31120 |
