Browse Forums Landscape & Garden Design Re: Irrigation - Connecting PVC pipe to tap 2Mar 23, 2015 8:20 pm Dependant on the stand pipe and tap material.... Galv. Or brass/copper "t" fitting inbetween the mains stand pipe and tape itself... Use Teflon tape. Then a male to male galv. Brass/copper threaded inline fitting with Teflon tap. Then use a inline PVC fitting , one end threaded (internal thread) with Teflon to the galv. Brass/copper inline fitting and then a slip joint on the other with primer and high pressure glue to the PVC pipe you want to connect to Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7331 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4873 DIY, Home Maintenance & Repair 3 pipes are coming from upstairs bathroom. 40mm from bathroom sink, 50mm from shower and another 50mm from the bathtub. Highly unlikely that any of these will be open at… 2 869 |
