Browse Forums Landscape & Garden Design 1 Mar 11, 2015 2:33 pm Hi all, I've got a 2m sewerage easement at the rear boundary. What will happen if I pour the concrete on the easement without the approval from the water authority? I understand that if I get the approval, I'll also need to bear the cost of removing the concrete if they need the access. So what's the difference of getting the approval or not? Thanks Re: Concrete over easement without approval 2Mar 11, 2015 3:08 pm Not much difference I can see. Do you need a slab for a shed?? Why not use prefab concrete blocks for shed floor knowing that if the Authority need access, you can move shed and its floor. Just my opinion. Re: Concrete over easement without approval 3Mar 12, 2015 12:23 pm bermuda23 Hi all, I've got a 2m sewerage easement at the rear boundary. What will happen if I pour the concrete on the easement without the approval from the water authority? I understand that if I get the approval, I'll also need to bear the cost of removing the concrete if they need the access. So what's the difference of getting the approval or not? Thanks You only normally need permission if you build a structure. Concrete paving doesn't need approval. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17108 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16104 Thanks - yea sounds like I need to submit build over easement application....ugh guess I better start finding someone who can do the engineering drawings 3 3320 |
