Browse Forums Landscape & Garden Design 1 Mar 05, 2015 11:22 am Hi all I recently moved into a new house and was wanting to get a start on laying some agg pipe out the front. Gonna connect it up to the existing drainage put there by my builder. Planning to run it along the portico, as that's where all the water currently pools up. How deep should I run it? Should I have it sitting above the current solid pvc or along side it? The drainage work my place needs has done my head in Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ OK it's been a little while! I've been busy getting time where I can to work on this. I started by grading a pad (borrowing a… 26 19968 Need more photos from around the house including your gutters. We have had 3 of the wettest years in a row for some time so that wouldn't be helping 3 6940 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 15692 |
