Browse Forums Landscape & Garden Design 1 Feb 18, 2015 7:19 pm Hey all Just need some advice as to whether our landscaper is doing the right thing. As per photos below, we are having some decking done at the back. I noticed one of the footing has a drainage pipe of some form going through it. Would it be an issue with the footing breaking the pipes?? Cheers ! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Decking Footing Advice 2Feb 18, 2015 7:31 pm It could have done with some lagging over it before the concrete went in which he may have done. Or even put some dirt back in to cover it, it doesn't appear to be supporting a huge load. Personally im more impressed the orga didnt rip it out, and wouldn't be bothered if he simply concreted over it as is. Re: Decking Footing Advice 3Feb 18, 2015 10:03 pm I did see another hole (no photos), the footing was directly on top of the pipe. That hole was not as deep as the others. Would it be a problem if the concrete over it? Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 15211 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10940 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7250 |
