Browse Forums Landscape & Garden Design 1 Feb 05, 2015 10:09 pm Hi, I am currently looking for landscaping quotes and have got the quotes in details below. I believe the decking and paving is overpriced but I am not an expert so I am seeking some advice to bargain the price down. Job Outline: • Site excavation. • Install timber edging. • Install crushed rock and toppings. • Install soil to lawn areas. • Instant turf. • Exposed aggregate concrete. • Granite towers. • Option A: Paving • Option B: Timber decking. Excavation and clear site: At completion of building by Carlisle Homes the site is to be void of all rubbish and building material and the site soil level to be left at approximately 80mm below the weep holes on the buildings. Should the site not be left in a clean state or if the soil level does not comply with the required level the supervisor will be notified and an additional cost may occur. I have made an allowance for poisoning weeds 2 weeks prior to job commencement and the use of a bobcat for 3hrs. Cost $450.00 GST $ 45.00 Total $495.00 Timber edging: Garden beds and lawns areas require the installation of timber edging. Approximately 78 lineal meters will be required throughout the house. Material to be used will be 70mm x 35mm treated pine timber, with lengths being pegged using a timber peg at approximately 1500mm intervals. Cost $1,350.00 GST $ 135.00 Total $1,485.00 Gravel toppings: Both sideways of house to have gravel toppings spread over compacted crushed rock. Approx area is 41m2. Cost $1,560.00 GST $ 156.00 Total $1,716.00 Soil installation: An allowance of 10m3 of soil will be supplied and installed to lawn areas only. Cost $1,100.00 GST $ 110.00 Total $1,210.00 Instant turf: 70m2 of “kikuyu” grass will be layed according to plan. Cost $1,400.00 GST $ 140.00 Total $1,540.00 Exposed aggregate: Supply and installation of approx. 48m2 of exposed aggregate concrete to driveway and laundry area. Exposed aggregate will be installed at 100mm thick on a 50mm crushed rock base. The concrete will be 25mpa and SL-62 mesh will be installed. Once cured expansions joints will be cut and areas will be acid washed and sealed with two coats of sealer. Cost $4,300.00 GST $ 430.00 Total $4,730.00 Granite towers: Supply and install of 3 large granite towers to front area. Towers to be concreted into ground. Cost $1,700.00 GST $ 170.00 Total $1,870.00 OPTION A. Paving: Supply and installation of 600mm x 300mm x 20mm bluestone pavers to alfresco and front porch area. Approximate area is 45m2 in total. A concrete base will be poured at 100mm in depth to extend areas. The base of the pavers will be covered with cement and then laid on a 20mm mortar bed and have an 6mm gap between each paver, which is then grouted using a bagged grout mix. A caulking compound will be used in expansion joints where the paving material meets another hard surface (i.e.-house). Cost $8,300.00 GST $ 830.00 Total $9,130.00 OPTION B. Timber decking: Approximate area is 45m2 of timber decking to front porch and rear alfresco entertaining area. The sub floor will comprise of 90mm x 45mm joists and bearers fastened to treated pine stumps. The decking material will be 140mm x 19mm Merbau fastened down with deck screws. Cost $12,500.00 GST $ 1,250.00 Total $13,750.00 Job total: Paving Option: $22,176.00 GST inclusive. Decking Option: $26,796.00 GST inclusive. Re: Landscaping quotes help! Somerfield Keysborough 2Feb 06, 2015 10:08 am Hazzatsa the costs sound reasonable to be. Decking and paving are generally very expensive. We did not pay any less than your quote. Just wondering why your landscaper chose kikuyu? It's so aggressive you will be forever pulling it out of garden beds. Some people like it because it's hard to kill. Re: Landscaping quotes help! Somerfield Keysborough 3Aug 24, 2015 4:29 pm Can think about bluestone paving. Pl have a look at the array of products at http://bluestone-pavers.com.au/ The friendly consultant will give you the best suggestion & quote. Re: Landscaping quotes help! Somerfield Keysborough 4Aug 24, 2015 5:31 pm Orpheus Building the Metricon Glendale 38|Sydney Re: Landscaping quotes help! Somerfield Keysborough 5Oct 15, 2015 4:34 pm I've no idea if the pricing is good, but gosh looks high! I need to get landscaping done and thought about having a professional come in, but at that price I'll be doing it myself. Would love to see your plan, it looks like it will be great. Re: Landscaping quotes help! Somerfield Keysborough 6Oct 15, 2015 5:08 pm The paving and decking looks reasonable albeit a little expensive the rest of it bar the excavation is a rip. To put it in perspective the kikuyu is 7 bucks a square meter from the supplier. Gravel is cheap as, well, rocks and treated pine is about 4 bucks a meter. Considered doing some of this stuff yourself? Also you could hire a labourer for 300/400 bucks to help you. Creator of superduperonium, expert at expert things, nobel laureate, can hold my breath for 10 minutes. Re: Landscaping quotes help! Somerfield Keysborough 7Oct 15, 2015 7:29 pm I reckon it all looks reasonable enough. Blue stone paving on a slab is around $250 - 300 m2 supply/install/grout/seal so you actually have a good price. Labour is the killer with landscaping.. It requires several guys/girls which are billed to you from $66+ an hour. Adds up quick. As mentioned the kikuyu supply/install seems high, the grass is about $500 delivered so another $1000 to roll it out is a bit rich, 2 hours tops for 2 people.. There is no soil prep as that is quoted seperately. So ask what the $1000 labour is for? Also don't forget that all supplied materials are about 20% dearer, which is the builders margin for organising it all. Hmmm, I have checked your past posts and it seems that you are in NSW, not WA as I had thought. It pays to show your State in your avatar. Retaining wall regulations… 5 8097 Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 35789 Ideally you would engage a landscaper to give you some insight what they may need in the space to make your vision come to life… 1 14026 |
