Browse Forums Landscape & Garden Design Re: Solar Lighting 2Oct 22, 2006 5:34 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Solar Lighting 6Oct 23, 2006 7:40 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Solar Lighting 7Oct 23, 2006 8:27 pm Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Solar Lighting 20May 30, 2007 9:50 pm devank Last week I saw 12 for about $50.00 or less at Bunnings. I'm not sure about the quality though. - devank Actually, those packages from Bunnings aren't really all that bad. They are el cheapo, plastic, fragile and all the other bad things, but.... I bought a pack of five, threw away the really cheap rechargable batties they come with and replaced them with quality ones, and put them along my driveway. The aren't enough to illuminate the whole drive, but as markers in the dark, they are great. My numpty son, who couldn't reverse in the dark if his life depended on it hasn't run off the driveway once since I put them in. They come on as it gets dark and fade away after about 5 hours. By the next night they are charged again. If all you can see are obstacles, you have lost sight of the goals Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28761 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8768 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8507 |
