Browse Forums Landscape & Garden Design 1 Nov 28, 2014 2:02 pm Hi new to the forum I have a 75 square metre "L" shaped area in my back yard which i need to level out, the depth ranges from about 0.5m to 1.7m. There will be a 1 metre retaining wall in place to hold back all the soil. What i would like to know is would you recommend filling that area with. (excluding drainage gravel) 100% top soil = expensive 80% cheap fill (recycled soil) + 20% top soil = cheaper is there any harm in using cheap fill as a base to raise the ground level or will it affect the top soil further down the track. or if anyone has had previous experience in filling a large amount in the back yard that would be handy any advice would be appreciated Re: Backfilling to level backyard 3Nov 29, 2014 7:38 am mgilla An even cheaper way is to call a few pool builders and tell them you will take x amount of fill if they are digging a pool close by. You should get that for nothing. Thats a great idea, never even thought of that DIY, Home Maintenance & Repair That laser level looks lovely! We bought one for less than a quarter of that price off eBay. It worked really well for us and it's still going now, five years later. After… 1 16781 It's possible but a soak well is usually much larger. Your 'soak well' only holds 424 litres when full. What is your soil type? Soak wells need sandy soils. 10 9076 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 24941 |
