Are soak wells commonly used in Melbourne?
I heard that in my area many years ago they used to use gravel pits but now it's all kerb and channel.
Browse Forums Landscape & Garden Design Re: Soakwells 3Dec 04, 2014 7:24 am Crazyk Are soak wells commonly used in Melbourne? I heard that in my area many years ago they used to use gravel pits but now it's all kerb and channel. Not in Melbourne itself too much clay to work. Down on the Mornington Peninsula they will work fine. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Soakwells 4Dec 04, 2014 11:18 am macmaz Hi Crazyk, have you found any solution for retaining storm water? My plumber used 100mm pipe because of the low fall, but an option to look at is getting a 2000l water tank and running your stormwater into that. Then the overflow goes to the street. The water in the tank can be used for your toilets etc. This gives you a head pressure from the tank to discharge. It's called a charged stormwater system. Have a bit of a search here it's been discussed at length. Cheers |
