Browse Forums Landscape & Garden Design 1 Oct 24, 2014 9:25 pm Hi We have built a retaining wall using adbri Versawall and have core filled and back filled with no fines concrete. After the initial pour(3 cubes) we were a little short and I need a little more to complete the wall. It is not enough to order a premix, and as I have access to a small mixer I was hoping to do the 'top up' myself. All of the 'recipes' I have seen, most talk about a 6 to 1 mix. So a couple of questions on this. 1: Is it by weight or volume? I assume volume, that is 6 shovels of aggregate to 1 of cement? 2: all mention to add enough water to make it like a paste. Does anyone have a more accurate recipe? Say, 6 shovels aggregate 1 shovel Cement and 'x' litres water? Thanks Brad Re: Retaining wall - no fines backfill 2Oct 25, 2014 8:29 am You will be best using a single sized agregate 6 shovels of aggregate to one of cement should be OK Water to cement ration is best by weight and you should aim for a bit less than 0.5 L of water per kg of cement. (its not critical for top up but more important for big pours) The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Retaining wall - no fines backfill 3Oct 25, 2014 8:50 am Thanks Bashworth. That gives me something to work with Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5190 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16147 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 |
