Browse Forums Landscape & Garden Design 1 Oct 23, 2014 6:09 pm I'd like to know if I can safely lower the ground level beside our house? I've knocked up a quick picture to show what I'd like to do. Currently the ground slopes from the house down towards the footpath (side street boundary). I'd like to level it off a bit, lowering the ground level beside the house by roughly 20cm. Is this safe? Would drainage be a concern? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Lowering ground level beside house 2Oct 23, 2014 11:44 pm You should have a 1:20 slope away from the house over 1 metre (50 mm over 1 meter). This is to prevent water pooling next to the slab and to protect the foundations from large variances in the subsoil moisture content. It looks like you either have or intend having a garden next to the house. Yes/No? This is not a real good idea. I know that the diagram is probably not to scale but from what I see, a 20 cm drop would be a very good idea. The main reason for this is that I have concerns as to where your damp proof course is. The DPC is under the weep holes. It would be interesting to see a photo, do you know how to upload a photo on H1? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Lowering ground level beside house 3Oct 24, 2014 7:30 am How far is that to the footpath ? What is there now ? Agree re slope needs - nothing worse than water - it can go/get anywhere. Re: Lowering ground level beside house 4Oct 24, 2014 8:01 am Aside from the excellent points raised above , by doing this you may compromise your termite proofing and/or make it a lot easier for termites to enter your home if that is a garden bed next to the house. This is roughly what you should have at the edge of your house... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Or for brick veneer on slab Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Stewie Re: Lowering ground level beside house 5Jan 04, 2015 12:18 pm Reviving this thread because it I want to clarify something for my situation. I'm planning on having a garden along a short section of wall (probably 10 metres in total, around a corner). I've probably got 200mm of slab exposed currently, then one course of bricks, then the damp proof course and then the rest of the bricks. My question is should I leave 75mm of slab exposed or 75mm below the damp proof course? My damp proof course has been installed above the first course of bricks Hi guys, I want to do some floor levelling before laying the planks and am considering doing it with self-levelling or yellow tongue PB board. I am wondering which one… 0 6598 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17607 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11839 |
