Browse Forums Landscape & Garden Design Re: Laying 400 x 400 pavers down the side of my house 2May 29, 2014 5:49 pm Use a mortar mix (brickies sand and cement) to lay the pavers, allow 50mm min for the bed. Set up the first and last paver to required heights. Set up two string lines slightly wider than these and lay to the lines. Landscape Design & Construction http://cherub.squarespace.com/ Re: Laying 400 x 400 pavers down the side of my house 3May 29, 2014 9:45 pm Quote: this has proven a nightmare as the wood is not perfectly straight in places and it is hard to keep the wood level. I bought several galv steel fencing rails from the local hardware store. These are cheap and straight. 2 of them are used to set up straight & level edges. The third rail is used to screed the bedding sand flat. Re: Laying 400 x 400 pavers down the side of my house 4May 30, 2014 11:19 am I would not have a clue how to 'level' cement between 2 string lines (and I don't really want to use cement). The galc fence rods sound like a good idea, however, what do you use to: 1.) make sure the galv rods do not move 2.) (And this is the cause of my main issue) - How on earth do I make sure the 2 rods are 'level'? what do I use to get the rods to be perfectly level on dirt that has a slight slope? If I could simply get the rods to be 1.) stable, 2.) the right height and 3.) level - I could then simply shovel in the crusher dust, use a screed to level the crusher dust and I am good to go. I am a complete noob at this stuff - so I appreciate peoples help. Luke. Re: Laying 400 x 400 pavers down the side of my house 5May 30, 2014 6:24 pm Steel fencing rails are square hollow steel sections. They are quite stiff & do not bend much. They can be held in position using tent pegs and partially burying in sand. Builders string & a long spirit level will allow you to accurately fix the fence rails in position. Then you shovel in bedding sand in between the 2 rails & screed off using another fence rail. The last time I installed concrete pavers, my enthusiastic 8 year old granddaughter screeded the bedding sand. Whenever she visits, she still inspects the paving. Re: Laying 400 x 400 pavers down the side of my house 6May 30, 2014 11:21 pm Thanks mate for the advice mate. The length Of the area I want to pave is 20m... how many rods should I get? e.g. if I buy 2x 4m rods... after I have Finished the first 4m how do I make Sure where I move the rods to is the exact same level? (I guess buying 4 rods would solve that...or a tape measure) nice memories with your grand daughter hehe Luke Re: Laying 400 x 400 pavers down the side of my house 7May 31, 2014 7:32 pm Quote: if I buy 2x 4m rods... after I have Finished the first 4m how do I make Sure where I move the rods to is the exact same level? (I guess buying 4 rods would solve that...or a tape measure) Laying pavers over 20m. To get a flat straight edge, use builder string. It will need a lot of tension to reduce sag in the middle. I suggest star droppers will be required at each end with a piece of timber in the middle to lift the string up a little to eliminate sag. Once you have screeded the first 4 metres, move the steel RHS sections along for the next 4m using the string line as a guide. In addition you could hammer in pegs/steel rods along the 20m to use as reference markers for the heights in case someone trips over the string! Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12291 Thanks for the photos. You need to know whether the inflow or the overflow pipe is leaking and this is a simple process of elimination. INFLOW: The vertical riser… 4 4684 The bottom of the downpipe has been taped (see the black tape) to seal the necessary gap between the downpipe and the adaptor that would normally prevent the downpipe… 3 9246 |
