Browse Forums Landscape & Garden Design 1 May 01, 2014 9:16 am Has anyone built one of the DIY sheds from the kit (from bunnings or similar)? Was it difficult or manageable? What flooring did you use? I am in Queensland, is anyone aware of what cyclone provisions might be required? Re: Anyone built a DIY shed? 2May 01, 2014 11:56 am I've built a small one around 2mx1m for my sister - it was straight forward but you really want two people to help hold things in place while you fix the sides together - we just mounted it to concrete path with some dynabolts. As there is no real frame to speak of I would imagine that strong winds would seperate the roof and sides. http://camdenbuild.blogspot.com.au/ by invite only please pm me Re: Anyone built a DIY shed? 3May 01, 2014 4:52 pm I've built decks, renovated houses and hands down the most frustrating thing I've ever built was the DIY shed. Metal is so flimsy and so were all the brackets etc Next time I would go Stratco and pay the $150 build cost. I used the Masters one and only a 2500mm x 1000mm or something similar. Re: Anyone built a DIY shed? 4May 01, 2014 8:34 pm I bought my shed online and built a timber base for it then bolted the shed to the base with steel L brackets. I managed to build a 3x1.5m shed by myself. Apart from interpreting foreign language instructions, the hardest part was holding the back wall, a side wall, a tek screw, and the cordless drill all at once. No idea about wind ratings etc. sorry. Re: Anyone built a DIY shed? 5May 18, 2014 7:17 am just finished putting up two sheds both on concrete bases 1.5 length took 3 hours to construct 2.2 length took 2 hours to construct used ezysheds but they are by no ways easy to put up. took two people as stated above they are filmsy and you need help when bolting together Re: Anyone built a DIY shed? 7Sep 22, 2014 2:35 pm built one - was a bit finnicky, and definitely a two man job, but in the end, got it all together and has been standing for nearly 3 years -no major issues! Hi All, we are starting to think of building with Masterpiece Builders in Victoria, has anyone had any feedback or experience with them 0 13587 I haven’t. But have a Lowe Design home. Not only did I find Matt Lowe patronising and a bully, but the home is NOT TO CODE. I have water coming through the bricks… 1 14045 Hi we are looking to talk to people who have built with them recently. We have signed mid range built contract but identified that a lot of things are not included.… 0 704 |
