Browse Forums Landscape & Garden Design 1 Apr 29, 2014 3:46 pm Hi all, I would like to make stone path with pebbles surround for my side yard. Hoping it would look something like this http://www.tuscanpath.com.au/images/pavers7.jpg Courtesy of qonyx: viewtopic.php?f=19&t=46973 Do I need a layer of paving sand before I lay the stone paver using cement?? I have compacted the soil and bought 600*300*20mm stone pavers. thanks Re: Stone path with pebbles surround 2Apr 29, 2014 5:39 pm No, the pavers can be laid directly onto a built up mortar base. Sand is normally used on larger areas and mortar is used around the edge to lock it all in, basically saving on the mess and cost of using mortar across larger areas. In your case each paver will just be locked in where it is. Re: Stone path with pebbles surround 3Apr 30, 2014 2:15 pm You will need some sort of edging as well. Timber is the cheapest to use and the easiest to install. Just dig the edging to the required depth and nail it to some timber pegs in the ground. Julian Dapple Landscape Design Landscape plans on sale for May & June only! Plans from $400, book today! http://www.dapplelandscapedesign.com.au/ Re: Stone path with pebbles surround 4Apr 30, 2014 3:38 pm Thanks for the replies! one more question, what type of concrete or mortar mix is most suitable for locking the paving stone in place? Is it sand&cement mix? https://www.masters.com.au/product/9019 ... ement-20kg or mortar mix? https://www.masters.com.au/product/9019 ... r-mix-20kg or concrete mix? https://www.masters.com.au/product/9019 ... e-mix-20kg Re: Stone path with pebbles surround 5Apr 30, 2014 4:36 pm mtz08 Thanks for the replies! one more question, what type of concrete or mortar mix is most suitable for locking the paving stone in place? Is it sand&cement mix? https://www.masters.com.au/product/9019 ... ement-20kg or mortar mix? https://www.masters.com.au/product/9019 ... r-mix-20kg or concrete mix? https://www.masters.com.au/product/9019 ... e-mix-20kg The mortar mix will be the easiest to work with. Alternatively you can make your own by using 6 shovels of brick sand to 1 shovel of grey cement. Julian Dapple Landscape Design Landscape plans on sale for May & June only! Plans from $400, book today! http://www.dapplelandscapedesign.com.au/ Looking for some advice on pool surround planting. We have roughly 500mm wide garden bed around the edge of our pool. Depth of the bed is only around 250-300mm to top… 0 3866 Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 12872 Thank you so much for your response. I have drawn a pedestrian gate in - for curb appeal, let's see how much costs come in at. I think you're right - if we decide to… 2 6529 |
