Browse Forums Landscape & Garden Design 1 Oct 04, 2006 8:38 am Hello all, this is my first post here. I'll try to make it quick. I'm installing a Nicolock Sierra garden stone, as a flower bed along the foundation of a house. The brick is 4" in height with two rows. I buried the first row an inch, so it was level with the step, for a total of 7" above the sidewalk. Do I run a string, or level each brick as I go? I tried going off the first level brick, and 5 bricks down that brick was level with the sidewalk, the first being 1" below the walkway. So I decided to run a string 3" above the walk way, now it looks even. What went wrong here?? Any help would be great, brick1 Re: Use a level, or use the sidewalk 2Oct 05, 2006 6:07 pm Just off the top of my head, is your land level or does it run slight down?
I think dig the hole the length of the bed, do a string line, then see if it all levels out. If not take more out or some back in. Then put your blocks in. Does that make sense? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 18008 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 6857 interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 47373 |
