Hi Everyone,
Just wondering what thickness steel they use for strainer posts and stays?
Looking at doing a rural fence at the moment and wondering if i need to go from 3.2mm to 4.5mm
Cheers,
Phil
Browse Forums Landscape & Garden Design 1 Feb 27, 2014 12:39 pm Hi Everyone, Just wondering what thickness steel they use for strainer posts and stays? Looking at doing a rural fence at the moment and wondering if i need to go from 3.2mm to 4.5mm Cheers, Phil You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7020 Seconded; we just used these last weekend to build a small deck. They worked perfectly as we have bluestone in the area where we wanted to build so digging down was not… 8 9053 |
