Browse Forums Landscape & Garden Design 1 Jan 13, 2014 11:59 pm I need to construct a 2 tiered retaining wall in my backyard (Campbelltown Council, NSW). The first wall will be approx 900mm in height & the second retaining wall will be approx 700mm in height. What is the minimum horizontal distance required between the 2 walls? Re: Minimum distance between 2 retaining walls? 2Jan 14, 2014 4:44 am Because the top wall can put stress on the bottom wall its really something that needs an engineers opinion if you want to build them closer than around 2m apart. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Minimum distance between 2 retaining walls? 3Jan 14, 2014 8:15 am I was hoping that it would only be about 1m & not as much as 2m. The ground level behind the second wall is flat/level for about 10m & doesn't continue to rise up if that makes any difference. Re: Minimum distance between 2 retaining walls? 5Feb 06, 2014 8:34 am It has as much to do with the type of soil and its cohesiveness as anything. If you are building the walls in sandy soils ( natural angle of repose is 70º ) then you would have to construct them further apart as Bashworth says. In clay soils ( natural angle of repose is 40º ) you could build them closer as Welby says. It will also depend on how far down you are going to anchor them and what type of construction you are going to use - sleepers and posts, conc. footing and reinforced and core filled besser block wall etc. Stewie 2 7929 My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 7106 Hi, only for walking. It is a narrow 1.5m paved area next to house. 2 5649 |
