Browse Forums Landscape & Garden Design 1 Jan 13, 2014 11:40 pm hi anyone done LED garden lighting? Wanting to do this and would like to see if anyone has done it on here. trying to find a driver that can be programmed to switch on and off, is this possible? or is there another way? search doesnt seem to find what I want cheers Re: garden lighting 2Jan 20, 2014 9:16 am Yes, all my garden lights are LED, but using new drivers that are equivalent to 35W or 50W halogens. From memory, recessed lights (into lawn) were about $80, and SS spike lights were about $140, all excluding install. There were also 2W LED very low profile eyelid style lights (gives the same effect, but under 1cm protrusion, so different construction), but those were $220 each. Back deck is lit with LED uplights, about $80 as well. They look great, but did get a lighting plan for the garden. Re: garden lighting 3Jan 20, 2014 10:40 am I only use solar LED lighting in gardens. It is excellent and costs nothing to run. You can have a long lead wire so as to put the lights in the shady parts. Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28814 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8816 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8580 |
