Browse Forums Landscape & Garden Design 1 Jan 09, 2014 10:01 am Asphalt (Hot Mix) driveway costs? Anyone had one done lately? I'm going to get some quotes but wanted a rough idea before i start. Would be looking at approx 200-300m2 of driveway to be done. I know concrete would last longer but i estimate concrete would be something like $45m2 and was hoping Asphalt would be cheaper? cheers http://www.betterthansheets.com.au - Why use sheets for curtains in your brand new home use Better Than Sheets Temporary Paper blinds instead! there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18280 Depends how much direct sun it gets. Is there any shading (eaves or trees)? If the sun hits a window directly it doesn't matter too much if it's double or single… 1 12645 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 12260 |
