Browse Forums Landscape & Garden Design Re: help in diy concrete paths 2Jan 08, 2014 10:27 am The cement and concrete association at http://www.concrete.net.au provide some great information. This is particularly helpful for a beginner http://www.concrete.net.au/publications ... Basics.pdf Other than that I would expect U tube to have some instructional videos. You need to be fairly fit is you plan to do a lot of concreting at one hit. Brian The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: help in diy concrete paths 4Feb 02, 2014 4:23 pm a few years ago I did a very small DIY path using a concrete mould. It worked out really well for some one like me. I used a mould from this company http://www.pavermaker.com/ and then did as they suggested in the instructions. I still have the mould I used as I keep thinking I may use it again one day for another project. It depends on what sort of path you are trying to build but for my purposes this was a good solution (and cheap!) Assuming the structure of your cabinetry is good then I would DIY everything as follows: - replace your counter tops entirely, - replace all drawer runners with soft close… 1 4782 |
