Browse Forums Landscape & Garden Design 1 Nov 19, 2013 5:16 pm I would like to fit a tap timer to the user end of the garden hose, not the tap end. This would allow me to swap attachments, or move the hose between 3 veg garden dribbler systems without having to make the trek to the tap and back twice with each change. Years ago Sabco made a timer with just a male thread each end which was ideal as you could then fit the male/female hose attachments as needed. They no longer make that model, and all of the timers that I have looked at have a female tap thread built in. Does anybody know of a timer that has the basic 2 male threads? If not, is there a simple way to achieve what I want? I have messed with a timer and various fittings, but it all starts to get bulky and often the timer is on backwards and won't work. Any suggestions appreciated. Re: Tap timer for the other end of the hose. 2Nov 19, 2013 6:25 pm It would be easy to make one up from a stock standard M-F, ask your friendly hardware/Bunnings store to do it. The plumbing dept has the necessary bits. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Tap timer for the other end of the hose. 3Nov 21, 2013 9:49 am "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Hey all Currently renovating our laundry, bought a new washing machine but have found that the drainage hose is alot shorter than the old machine (which I used to get the… 0 17525 Minimum overhang into gutter must be 50mm, turn down tool should not split the sheet. it seems wrong tool for the profile was used, the flashing cannot slope back. Rib… 2 2130 Electrical just got back to me and said the most they can provide is a single power point on the Bedroom 1 side of that wall. After handover, your towel rail installer… 2 3850 |
