Browse Forums Landscape & Garden Design 1 Aug 21, 2013 10:03 pm Hi all, I luv the look of the fence in the below look and hoping some one can suggest a fencer in Melbourne that can supply and install such a fence. http://glamourdrops.com/2012/08/31/woul ... al-inside/ It is a requirement in the estate I am building to have a front fence, and there are specific requirements for the fence. I am hoping the developer will accept this fence as a 'picket' fence. It is not a traditional picket fence, but it could be said that each post is itself a picket. I will be seeking approval before building. I will complimenting the fence with either of the letterboxes in the below links. http://www.poboxdesigns.com.au/view/1078 or http://www.poboxdesigns.com.au/view2/1156 I am also open to any advice on how I would do this myself if need be. Would I just require a trench, then brace all posts in place and backfill with concrete? Thanks Shane Re: Modern Front Fence 2Sep 05, 2013 11:18 am Quote: I am also open to any advice on how I would do this myself if need be. Would I just require a trench, then brace all posts in place and backfill with concrete? That is pretty much it. Stewie Old Home Restoration / Renovation Try your local council. They should be able to advise in regards ownership of next door dwellling and give advice as to what steps you have to take before doing any work 1 9852 I recently finished my house and after landscaping, have begun to plan a fence. To be honest its been a bit of an afterthought so I'm after some much needed advice. The… 0 2117 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9227 |
