Browse Forums Landscape & Garden Design Re: What's drilling holes in my lawn? 4Aug 18, 2013 4:15 pm Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: What's drilling holes in my lawn? 8Sep 21, 2013 11:23 pm Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: What's drilling holes in my lawn? 9Sep 25, 2013 10:51 pm Building the Montague 21 by Porter Davis at The Estuary, Leopold. Our Blog: http://porterdavismontague21.blogspot.com.au/ Re: What's drilling holes in my lawn? 10Oct 08, 2013 10:04 pm Hey Jazz, just to cancel everything out and depending on where you live, if they have only just appeared this spring then it is very possible they are cicada hole, they feed of the roots of the trees and then come up, this season has been immense with alot about. Pretty amazing as they come out of the ground after 17year almost exactly to the day that they went under ground. Good luck with your investigations. I use Tramex moisture meter and it will tell me instantly if the wall is cement sheet or plaster or masonite but most people dont have the equipment. 5 7045 it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7063 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 5405 |
