Is this a serious issue or not
Hi Guys please take a look that this photo. It is of my maple tree. The tree has always looked ok however I am not sure if I need to treat this or not. Lucky it didn't snuff it from that much damage. If it doesn't leaf out or starting looking very crook then call an consulting arborist (if the tree means a lot to you)..
I also want to put a box around the tree so the grass is not right up to it. If I raise the soil close to or even above this damage is this a problem??
Yep a big problem, best way to kill a tree is to put soil fill over an existing trunk and root system. If you want to box it in instead of using soil use a coarse aggregate like scoria. This allows airflow to the trunk, which will stop the trunk rotting, and allows air to the roots system which is what is keeping your tree alive. For decoration you can put a light layer of chunky wood mulch or decorative pebbles on top of the ugly scoria.
thanks, I think I will use decorative pebbles I already have. Looks like I have some work to do.
2
Thanks for that!
19/07/2023
8
thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover.
27/07/2023
2
Does it wipe off? Could be because of dry dirty drips.
