Browse Forums Landscape & Garden Design 1 Apr 22, 2008 10:34 am Hey All,
Just thought i would post this question to see if i can get some help. We have started to build our gates setting Merbau posts and welding the stainless stee frame. We obviously oiled the posts before erecting them. We now cant get a hold of the Merbau 90mm slats that we are after but can get our hands on Batu. My question is, can i use the Merbau Oil on Batu? I bought so much of it I don't want it to go to waste!!! And advice would be appreciated. Thank you! Re: Merbau & Batu Timber Question 2Apr 22, 2008 6:03 pm you can use any quality timber oil on batu
the only draw back to batu is there is almost always small borer holes in it were do you live almost all bunnings sell 90mm merb. Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Merbau & Batu Timber Question 4Apr 23, 2008 7:49 pm Another 'gripe' against China for the Beijing Olympics - they have used about 200,000 cubic metres building the vilages etc. Re: Merbau & Batu Timber Question 6Apr 27, 2008 3:07 pm davinci you can use any quality timber oil on batu the only draw back to batu is there is almost always small borer holes in it were do you live almost all bunnings sell 90mm merb. We are having Batu so I will have to check this out. Not sure if I want borer holes in the decking .... Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15919 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6156 The most likely cause of your timber swelling (parquetry?) is either a plumbing leak or carelessly leaving water on floors after use or both. Without seeing, i am ignoring… 1 3280 |
