Browse Forums Landscape & Garden Design 1 Jan 21, 2013 10:50 am Hi all, I'm looking to build a retaining wall from treated pine sleepers, since unfortuately can't afford to use the coloured concrete blocks. Anyway, in attempt to minimise warping I'm thinking to use coach bolts into 75mm (or 100mm) sleeper uprights rather than H channel, with 75mm sleepers. Are there better quality sleepers that may be less prone to warping, ie Bunnings grade vs Timber yard grade? Also what spacing for the uprights will help reduce any warping? The wall will be around 20m in length & probably 4 sleepers high. Thanks for any info Re: Treated pine sleeper retaining wall question 2Jan 22, 2013 6:07 pm I made a small retaining wall similar to what you are considering a few months back, used 100x2400 pine sleepers from bunnings, with vertical sleepers cut to height and concreted in at 600 deep, 2 sleepers high and all put together with coach screws. Mine is still quite new with no warping yet, but I don't see it being an issue. Here is a shot of it to give you an idea... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Treated pine sleeper retaining wall question 5Jan 31, 2013 12:53 pm Hi, Check out my thread - it's got a bit of everthing in it including a treated pine retaining wall. I havent updated it for a while though. Been far too busy. viewtopic.php?f=19&t=44663 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5197 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6591 Iām just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise… 0 52859 |
