Browse Forums Landscape & Garden Design 1 Dec 09, 2012 9:04 am Hi guys - just thought I would share my retaining wall. Built ourselves with the help of a friend. I used the Retain-it H galvanised steel posts and 75mm treated pine sleepers. Retaining wall and agg pipe ready to go. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Painted with Bitumen to protect from rotting Dirt filled (didn't get a photo with crushed rock on agg pipe) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Sorry for the glare - retaining boxes to protect fence.. Now just waiting for the rest of the yard to be leveled for grass and this section will have crushed rock on top mixed with a bit of concrete so it will be level all the time Re: My retain-it retaining wall - almost done! 2Dec 11, 2012 7:36 am You did a good job -only thing watch out for the ag drain becoming silted over. This happens to a lot of people and the drain stops performing its function. cheers Re: My retain-it retaining wall - almost done! 3Dec 11, 2012 9:04 am leighton You did a good job -only thing watch out for the ag drain becoming silted over. This happens to a lot of people and the drain stops performing its function. cheers Oh thanks - Does that mean it gets clogged with dirt? Re: My retain-it retaining wall - almost done! 5Dec 18, 2012 6:14 am Eoh Nice, I'm actually considering at using Retain-It as well. What's d span between each post? I just used 2.4 m X .75m sleepers for mine with the small end at about 70cm long. Re: My retain-it retaining wall - almost done! 6Dec 18, 2012 11:02 am Victoria_g06 Eoh Nice, I'm actually considering at using Retain-It as well. What's d span between each post? I just used 2.4 m X .75m sleepers for mine with the small end at about 70cm long. Thanks. I was gona use the same exact setting but now I am leaning towards more at having 1.5 or 1.8 span. I am concern about the warping / bowing of the timber. However, it'd cost more as I then need to buy more Retain-It Post. Other option I have in mind is to use the 2.4 or 3.0 (like yours) then install Timber Post support in the middle as opposed to cutting. Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5196 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16156 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 |
