Browse Forums Landscape & Garden Design 1 Nov 19, 2012 12:39 pm So I am about to embark on building a privacy screen in my backyard, I am quite handy with the tools having built numerous decks, retaining walls and renovated a couple of bathrooms, but as always I am turning to you faithful H1 members for some advice The screen will be 6m W x 1.9M H. Post are 100mmx100m Cypress Pine, approx 1m apart. The frame will be treated pine 90mmx45. I plan on covering the entire screen with 7.5mm blueboard, and this will be finished off with a combination of feature tiles, render and decorative laser cut timber panels. Would anyone recommend I also brace this screen from behind with metal strapping ? not sure of the correct technical term for these. But you see them on all internal house frames, running diagonal across the wall before the plaster is applied. Or would you think the blueboard we be enough to prevent any bowing/movement of the screen ? Re: Privacy Screen Advice 2Nov 19, 2012 6:28 pm Unable to answer your question as I am not a builder, I do have some questions of my own. Are you planning on building the screen against one of your boundaries or will it be located elsewhere in your backyard? Would love to see photos during construction and when it's complete! Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: Privacy Screen Advice 4Jan 06, 2013 2:39 pm don't know about pine, but I brought the cheap decking material from bunnings for about $3m and cut them to about 2m lengths and used the same decking material for posts and it worked for me. I don't think you will need bracing if they are 1m apart. Hi guys We have just removed a very large grape vine which was mounted to a structure along this wall. This is a shared wall with our neighbour, and after removal, we… 0 3954 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7075 |
