Browse Forums Landscape & Garden Design 1 Oct 28, 2012 7:40 am Building Henley Monaco Nouveau Q1 - Mernda Villages https://forum.homeone.com.au/viewtopic.php?f=31&t=57810 http://razbuild.blogspot.com.au/ Re: Question about paving. 2Oct 28, 2012 8:36 am The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Question about paving. 4Oct 28, 2012 3:27 pm Building Henley Monaco Nouveau Q1 - Mernda Villages https://forum.homeone.com.au/viewtopic.php?f=31&t=57810 http://razbuild.blogspot.com.au/ Question about paving. 7Oct 28, 2012 9:11 pm Jasmin Hickinbotham Belmont - modified Signed: February 2011 Slab should go down before 2012 My build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=52310&p=799483#p799483 Re: Question about paving. 8Oct 28, 2012 9:46 pm Building Henley Monaco Nouveau Q1 - Mernda Villages https://forum.homeone.com.au/viewtopic.php?f=31&t=57810 http://razbuild.blogspot.com.au/ Re: Question about paving. 10Oct 29, 2012 12:21 pm Absolutely, over time ground underneath will compact, and even small amounts will lead to unevenness. While you can use a vibrating plate to compact it while you're putting it down, it will still compress more over the life of the area. Lilydale topping, being that it comprises largely of granetic gravel, will compact to about 40% of its original volume (we use both for making BMX tracks and pump tracks). The trick is to make sure it's adequately drained. Building a Delta 21 at Craigieburn - http://homeofzero.blogspot.com.au/ Deposit: 26/02. Contract: 22/05. Settlement: 29/05. Site start: 18/10. I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12357 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5718 |
