Browse Forums Landscape & Garden Design 1 Oct 16, 2012 10:34 am Hello, I'd like some advice. What steps do i need to take to turn a hole left from an above ground pool to a lawn. The hole is about 5m x 4m and 60cm deep. What do I need, how do i do it? I am very much a novice but dont mind getting on the shovel so if i can do it without machinery it would be preferred! Re: how to fill hole left by above ground pool?? 2Oct 16, 2012 6:31 pm You could ring a local pool builder. They are always looking for places to dump soil that they remove from installing pools. Tell them you'll take the clean fill for nothing. Of course you need good acccess if you want it dropped in the hole. Sometimes people advertise free clean fill. You'd have to pack it down or let it settle then put topsoil and lay turf or plant lawn seed. Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11763 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 13663 you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3661 |
