Laying turf question
I rotaryhoed the crap clay fill and then spread composted soil and rotaryhoed it all again as well as adding biochar, bactivate and seamungus to the mix.
I plan to plate compact and pick out any large bits bigger than a few cms but there is a fair bit of bark type material mixed through the soil.
Don't want my new turf to curl up and die on me!!
With sand (ie Perth) all the soil particles are roughly the same and you can whack it all you like and you won't change the soil structure. You can also whack loam soils a little bit without issues.
Beatrixkiddo, I remember you posted somewhere saying adding sand to clay soil if the turf area is to play on. My local nursery has a list like - yellow lite brick sand, Skye white brick sand, TGS white sand, white sand, washed concrete sand and packing sand. May I ask what sort of sand do I need to get and how many cubic metres do I need for an area of 4x16m?
Thanks
Edit: 1 more question, would it be a good idea to run a couple of slotted AG pipes in that area?
I'm about to put down some Merbau. Is it necessary to oil underneath the boards before laying?
1/03/2024
7
Hey There. No problems re jumping in. My original question was "should I have waterproofed" the concrete slab before putting batons down. We have been told we should…
27/02/2024
3
They using concrete or timber sleepers? Timber or steel uprights? Any drainage behind sleeper?
