Browse Forums Landscape & Garden Design Re: mulch mower and newly laid turf? 22Sep 01, 2012 2:57 pm Lex OMG, sounds like couch is worse than kike ?!!? How's that possible !?!? Fu, can it be killed with once a year weed killer ?! At least at the edges where is starts going under the fences ... Good luck. It can only be successfully controlled with Fusilade. Using other things will waste your money. The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15845 I had new concrete laid, extended the alfresco and had the sidewalks concreted too. I noticed the concreter didn't put the expansion foam anywhere, there are expansion… 0 8162 They using concrete or timber sleepers? Timber or steel uprights? Any drainage behind sleeper? 3 5962 |
