Browse Forums Landscape & Garden Design 1 Jun 25, 2012 11:59 am ok its time to seriously start getting things ready for our retaining and water runoff etc etc
anyone purchased CCA treated timbers in sa area? we are barossa valley based and wondering if anyone has any contacts or places that supply ive found a quite a few online but all are interstate (mainly qld) im guessing B#$#ings dont have them (or didnt seem to last time i looked) as their sleepers were 16 bucks each way to cheap for cca treated so if anyone knows of anywhere around the sa area that has this type of sleeper a link or contact would be appreciated ps we are now up top lock up stage so hopefully come end of sept we're in! thanks guys and girls Re: CCA treated pine 'sleepers' in SA 2Jun 26, 2012 12:56 pm seriously 16 views? maybe i should of put 'sleepers' in the title Re: CCA treated pine SLEEPERS in SA 3Jun 28, 2012 4:35 pm Have you tried calling your local timber merchants? Landscape Design & Construction http://cherub.squarespace.com/ Re: CCA treated pine SLEEPERS in SA 4Jun 29, 2012 6:27 am I think your after ACQ treated pine sleepers not CCA. CCA are the cheaper of the two. ACQ is still a bit hard to find, Bunnings can order stuff in and they usualy are cheaper than most places, including staright from the manufacturer. Re: CCA treated pine SLEEPERS in SA 5Aug 13, 2012 12:09 pm thanks jetson im slowly being talked into concrete sleepers by a mate at work who has done a few retaining walls i need a few tho im guessing at least 100 im worried about lifting them in will only be two people doing the work although i might be able to get a local guy with a bobcat and a sling to aid us im being talked out of treated because im told they will bow and wont last as long yet im reading the new treated timbers will last up to 30 years a mate told me he used hardwood and they still bowed slowly im being talked into concrete ones Re: CCA treated pine SLEEPERS in SA..Hmmm maybe concrete??? 7Aug 15, 2012 12:09 pm concrete ones are the way to go so far cheapest ive found (plain 2m by 200 by 80) is 29.50 each but when i said id need around 150 he knocked a buck off each sleeper....generous lol if i can get them for 25 each id be happy DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6585 Iām just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise… 0 52856 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10971 |
