Browse Forums Landscape & Garden Design 1 Jun 18, 2012 12:25 pm I laid a thick layer of lilydale topping down in the nature strip a few weeks ago, about 100mm on average, compacted it with plate. All good until our neighbours and some very inconsiderate citizen decided to cut corner and drive over it. See photos below. The area concerned is the lowest part of the nature strip, it has never been dried and after all these miserable weather we have so far, it's waterlogged and spongy. What went wrong and what can I do? Any input will be really appreciated. Built: Modified H3nl3y S0h0 Q1 in Melbourne :- Never again Re: Another Lilydale Topping issue - advices please 2Jun 18, 2012 12:56 pm Subbase preparation has let you down, compacted subbase with plate, add road base 100mm cement stabilised and compact. 75mm of topping stabilised with cement to 5% then compacted Landscape Design & Construction http://cherub.squarespace.com/ Re: Another Lilydale Topping issue - advices please 3Jun 18, 2012 3:13 pm wow that's a fair bit of stuff missing down there i guess. cherub, is there any other ways of fixing it given the Topping has already laid? I was thinking of doing another topping to make it flush with the foot path and kerb down the track as you can see from the photos, it's a bit off ATM. Can I just shave it down 50mm, add cement and compact, then top it up with another 75mm topping with cement added and compacted? Built: Modified H3nl3y S0h0 Q1 in Melbourne :- Never again Re: Another Lilydale Topping issue - advices please 4Jun 21, 2012 8:39 am It's pretty hard to fix properly with a poor sub-base If you add more toppings mix in off white cement, also as you say lift the level so no water pools on the surface Landscape Design & Construction http://cherub.squarespace.com/ Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and… 0 10924 thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 16176 |
