Hi H1-ers - did any of you use the Dulux Acratex render?
Could you please let me know if you are happy with the result and if you can remember the cost?
TA
Browse Forums Landscape & Garden Design 1 Apr 05, 2012 10:38 am Hi H1-ers - did any of you use the Dulux Acratex render? Could you please let me know if you are happy with the result and if you can remember the cost? TA Preliminary agreement 23/11 Contract 22/03 Prestart 06/04 - finalised on 30/04 Unconditional approval 10/05 Demolition 05/07 Slab 26/08 Brickwork 13/09-06/10 Roof frame started 07/10 viewtopic.php?f=31&t=32292 Re: Dulux Acratex render 3Apr 05, 2012 11:13 am thanks B Star - would you recomend another acrylic type render? Preliminary agreement 23/11 Contract 22/03 Prestart 06/04 - finalised on 30/04 Unconditional approval 10/05 Demolition 05/07 Slab 26/08 Brickwork 13/09-06/10 Roof frame started 07/10 viewtopic.php?f=31&t=32292 Re: Dulux Acratex render 5Apr 05, 2012 1:53 pm Thanks again - wondering how much Acratex we need to render our feature planters/water/screen - if anybody can give us an idea would be great. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ http://i908.photobucket.com/albums/ac281/ddmayred/DSC_0227.jpg http://i908.photobucket.com/albums/ac281/ddmayred/DSC_0226.jpg Preliminary agreement 23/11 Contract 22/03 Prestart 06/04 - finalised on 30/04 Unconditional approval 10/05 Demolition 05/07 Slab 26/08 Brickwork 13/09-06/10 Roof frame started 07/10 viewtopic.php?f=31&t=32292 Re: Dulux Acratex render 6Apr 05, 2012 2:04 pm from memory it does about 5 square meters per tub. But you will need to Render the at least one coat with a acrylic cement render (non Color). Now a question for you. What material did you use to build the frame for the wall. Re: Dulux Acratex render 7Apr 05, 2012 2:13 pm Ok - so you might need to explain a bit on "But you will need to Render the at least one coat with a acrylic cement render (non Color)" . Am I correct in assuming that you usually do 2 coats of render – one is acrylic cement render and the last one is Acratex? Obviously I'm not so spec'ed up on the exact process. The frame for the back wall is galv. steel which DH will cover with blueboard this weekend. Preliminary agreement 23/11 Contract 22/03 Prestart 06/04 - finalised on 30/04 Unconditional approval 10/05 Demolition 05/07 Slab 26/08 Brickwork 13/09-06/10 Roof frame started 07/10 viewtopic.php?f=31&t=32292 Re: Dulux Acratex render 8Apr 05, 2012 2:17 pm First up you use bags of render that you add water to and apply to the brick work. I think in your case one coat should be enough. Once this dries really good, then you add the colored render on top. You will also need to consider a jointing compound for the joins in the blue board. Re: Dulux Acratex render 9Apr 05, 2012 2:30 pm B Star please bear with me on this ok - I thought that on blueboard we are supposed to use an acrylic based render only - that's what I understood from the myriad of threads I've been reading. The Acratex is supposed to have some stretch (sorry not a very technical term here ) and not crack as easily as the normal cement render will do on contraction/expansion. If we are doing a first coat of normal cement render then applying the Acreatex on top, isn't that going to go against the idea? RE the jointing compound - we are going to look for a flexible one and tape for strength. As well DH wants to use SS screws to attach the blueboard onto the frame and we are using beading around all edges. Preliminary agreement 23/11 Contract 22/03 Prestart 06/04 - finalised on 30/04 Unconditional approval 10/05 Demolition 05/07 Slab 26/08 Brickwork 13/09-06/10 Roof frame started 07/10 viewtopic.php?f=31&t=32292 Re: Dulux Acratex render 10Apr 05, 2012 2:53 pm There is special blue board render that can go on first. the jointing compound ensures things dont crack. Either way do not use normal cement render, ensure it is acrylic cement render for blue board. Its more expensive than regular acrylic render 20 to $30 per bag. This has better fill properties that the acretex. Re: Dulux Acratex render 11Apr 05, 2012 2:59 pm Thanks B Star - it's so good to have experienced people on this forum. Much appreciated. Preliminary agreement 23/11 Contract 22/03 Prestart 06/04 - finalised on 30/04 Unconditional approval 10/05 Demolition 05/07 Slab 26/08 Brickwork 13/09-06/10 Roof frame started 07/10 viewtopic.php?f=31&t=32292 Re: Dulux Acratex render 12Apr 05, 2012 4:35 pm B Star would you like to recommend me an acrylic cement render to suggest to our rendering guy? I think he quoted us on using normal cement render as he was saying that we need sand so I would like to forward this info to him and ask him to quote and use the acrylic cement render. Preliminary agreement 23/11 Contract 22/03 Prestart 06/04 - finalised on 30/04 Unconditional approval 10/05 Demolition 05/07 Slab 26/08 Brickwork 13/09-06/10 Roof frame started 07/10 viewtopic.php?f=31&t=32292 Re: Dulux Acratex render 13Apr 05, 2012 6:39 pm We have Acratex on our outdoor feature screens and planters. The planters are Besser block and the screen blueboard. We've also used it on our bar. Can't tell you what it cost, but it still looks great. Re: Dulux Acratex render 14Apr 05, 2012 9:41 pm thanks kek- been admiring your back yard for a long time hopefully ours will turn as nice your plants must be well established now Preliminary agreement 23/11 Contract 22/03 Prestart 06/04 - finalised on 30/04 Unconditional approval 10/05 Demolition 05/07 Slab 26/08 Brickwork 13/09-06/10 Roof frame started 07/10 viewtopic.php?f=31&t=32292 Re: Dulux Acratex render 15Apr 06, 2012 4:27 pm Bagheera thanks kek- been admiring your back yard for a long time hopefully ours will turn as nice your plants must be well established now They're a bit feral... I just cut down the cannas so we could re-seal our merbau screens. Everything is growing like the clappers. I keep meaning to post some updated photos...need to find time to weed and tidy up first. Re: Dulux Acratex render 16Apr 08, 2012 9:44 pm professional renders usually like to use unitex. I dont you well get away with sand a cement of blue board. It need to be flexible, and water proof. The acrylic render is better for those two reasons. Re: Dulux Acratex render 17Apr 17, 2012 3:08 pm ok, it seems that there are not many renderers in Perth doing/knowing about the Acrylic Cement Render or the ones doing it are charging quite a lot. I've been quoted for a full Acratex sealant/render/Coventry Coarse 951/Acrashied system over $3K??? Can anybody recommend a renderer in Perth who is decently priced? Preliminary agreement 23/11 Contract 22/03 Prestart 06/04 - finalised on 30/04 Unconditional approval 10/05 Demolition 05/07 Slab 26/08 Brickwork 13/09-06/10 Roof frame started 07/10 viewtopic.php?f=31&t=32292 Re: Dulux Acratex render 20Apr 17, 2012 3:40 pm Hi mikeg12 - we used Eco blocks - aerated concrete - similar with Hebel but they are full blocks. Footing is cement with aggregate (didn't use rheo). Preliminary agreement 23/11 Contract 22/03 Prestart 06/04 - finalised on 30/04 Unconditional approval 10/05 Demolition 05/07 Slab 26/08 Brickwork 13/09-06/10 Roof frame started 07/10 viewtopic.php?f=31&t=32292 Hi Alex, Thanks for the reply again. I had a chat with the builder, he said he will use primer, then hydrotec which comes with colour and sealer as well. A Renderer I… 12 17995 I am looking for someone who might have tackled a similar issue as me. I have a few rendered interior walls, the surface condition is hardly flat. I can see all the bumps… 0 7938 |
