Browse Forums Landscape & Garden Design 1 Mar 02, 2012 8:36 am hi, A few wks ago I found one large patch of yellow leaves in my pittosporum . Already gave the standard brew Fu mentioned. I also trimmed some off. Today, I found the tree with most of the yellow leaves off, leaving those twigs. A few twigs still got green leaves. Should I trim those bare twigs off? ( that means nearly pruning 1/2) ? Or will new leaves start from the bare twigs then? Thanks a lot. Spring is here! Hurray! 7 3006 The HIA contract, in the term & conditions section states that "Commencment" is deemed when the drainage is started or the piers are dug or the slab is formed up (incase… 2 6177 DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31280 |
