Browse Forums Landscape & Garden Design 1 Feb 22, 2012 5:47 pm Hi, As part of a construction project we have built a retaining wall. We had initially planned to render and paint it because we are doing the same with the rest of the house, however my wife has found out about sandstone cladding and has her heart set on it. I am trying to do some rough budgeting to figure out how much extra it is going to cost us. The retaining wall is about 50sqm. It is comprised of 4 differently-sized sections, the tallest being about 3m. It is built using standard concrete blocks (roughly 400mmx180mm). It is 100% vertical. We have selected the cladding we like, cost is around $160 per sqm (Retail). We also need to consider capping and corners, but that is a discussion for another day. What I am after is a rough guide of the costs for the installation of the main cladding described above, including any prep work, grouting etc. Any other information would also be appreciated. Thanks Re: Retaining Wall - Render+Paint vs Sandstone Cladding 2Feb 23, 2012 5:11 am What size is the cladding, is it real stone? Landscape Design & Construction http://cherub.squarespace.com/ Re: Retaining Wall - Render+Paint vs Sandstone Cladding 3Feb 23, 2012 3:04 pm Thanks for the response. According to the brochure: "Split face veneer split on 5 siders and sawn on the back. Randon square an parallelogram shaped stone pieces up to 300x300mm. Thickness 20-40mm" Addtionally: "Typically these products are adhered to a concrete or block wall with a suitable tile adhesive." Re: Retaining Wall - Render+Paint vs Sandstone Cladding 4Feb 23, 2012 3:13 pm Without see the stone and knowing joint sizes etc., would be expecting around $4800+ to install That's quite a large area consider using render plus stone Landscape Design & Construction http://cherub.squarespace.com/ I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12389 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5179 Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4480 |
