When to plant Chinese Tallow
Also, we have sewerage pipes in the front yard, not too far below the surface, I've been told that Chinese Tallow have quite deep root systems, so how far away from the pipes should it be planted?
Someone else was asking about them on here before. Fu suggested a pecan tree might be better as it only grows to around 4-5m. ( you won't get pecans for many years though before you get too excited) Or even a pistachio .
Just had a quick look at your blog. I got a real excitement from seeing your build pictures. Hope that doesn't mean I want to build again. LOL anyway good luck with your build. One heads up: Once your roof is on have a good look at how dark that front passageway is. Ours has the same bend in it and although longer I suspect you might find yours will be a little dark also. On the list for us now is a solatube of some kind.
Also, our house is actually complete and we've been living in it for almost 2 years now, once the house got to the stage it was on the blog, we started to have to organise things for it and updating the blog became another chore and as a result got abandoned. Perhaps one day I'll do a completion entry. The front passage gets a little dark, but nothing problematic, a new front door with some glass in the top is on the wish list though.
8m is still a small tree. It's also great to know that they'll do well looking at how they've gone so far in the street.
In regard to trees, I see them done badly in every estate. Trees aren't always chosen because they are suitable. More often than not it's because they were obtained cheap or the designer didn't give a rats as long as they looked pretty on paper and when planted.
Best time to plant a tree was 20years ago. The second best time is right now.
Sent via Tapatalk
