Browse Forums Landscape & Garden Design 1 Feb 08, 2012 10:04 am Hi All, Im going to do my own retaining wall and have come across concrete sleepers. They are around 3 times more expensive than pine. Would it be worth it? I gues you would never have to replace them? Please let me know your thoughts/ opinions because it is quite a lot more money and I want to know if it will be well spent. Thanks! Re: Concrete Sleepers or Treated Pine? 2Feb 09, 2012 10:49 am Have you thought about how you will lift them? Concrete will last longer but cost shouldn't be 3 times IMO and they are pretty heavy so a well thought out process or access to a machine to lift them is a must. Re: Concrete Sleepers or Treated Pine? 3Feb 09, 2012 11:23 am chrisandkate Have you thought about how you will lift them? Concrete will last longer but cost shouldn't be 3 times IMO and they are pretty heavy so a well thought out process or access to a machine to lift them is a must. Oh thats true, I did hope to have everything ready so when thy deliver them we can just position them in. I have been thinking and I really can't afford them at the moment a $3,000 wall isn't viable, whereas I can get all materials for under $1,000 by working with treated pine. I just didnt know if anyone else had done it or thought about doing it. Thanks for your feedback Re: Concrete Sleepers or Treated Pine? 4Feb 12, 2012 10:38 pm I was looking at concrete sleepers too and found this mob in Brisbane, http://www.wix.com/sponge2222/main#!prices Not to bad compared to timber. DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6585 Iām just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise… 0 52856 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10971 |
