Browse Forums Landscape & Garden Design 1 Jan 08, 2012 7:35 pm Hello all, I have been looking to try and do my own retaining wall but the only bit I don't understand is how the agg pipe works? Do I have to connect it to a drain pipe from the house? How does the water get in there to drain away? There are retaining wall how to's out there but they all just mention laying the agg pipe but doing nothing after that. Any help would be appreciated! Thank you Re: Confused - How does Aggregate piping work? 2Jan 08, 2012 8:54 pm Probably the simplest thing to do is let it discharge at the bottom of the wall either onto the garden or paving where it will get to a drain. (the flows should be fairly small. Other alternatives are A soakwell -You will find a thread for this A drain connection you will need a plumber to make the connection The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Confused - How does Aggregate piping work? 3Jan 09, 2012 6:41 am Hmm, I think letting it drain at the bottom of the wall but I am facing it towards my side fence and there is a footpath on the other side so no drain nearby, would that be ok? Re: Confused - How does Aggregate piping work? 4Jan 09, 2012 8:20 am My other half is a plumber, he can come and quote on an agg drain, he did ours, and we've never had any flooding, or any water issues. Even Christmas day with all the storms, we didn't have any water on the ground in our backyard. The agg drain goes inside the retaining wall, and is covered with crushed rock. The water will soak into the pipe. The pipe is then run on an angle towards a pit or storm water drain, which the plumber will connect it to. Message me if you're interested in getting a quote? We're heading west this weekend coming Re: Confused - How does Aggregate piping work? 5Jan 09, 2012 10:29 am Victoria_g06 Hmm, I think letting it drain at the bottom of the wall but I am facing it towards my side fence and there is a footpath on the other side so no drain nearby, would that be ok? I would need to see a plan or photo before I could give an opinion. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Confused - How does Aggregate piping work? 6Jan 09, 2012 10:31 am bashworth Victoria_g06 Hmm, I think letting it drain at the bottom of the wall but I am facing it towards my side fence and there is a footpath on the other side so no drain nearby, would that be ok? I would need to see a plan or photo before I could give an opinion. Yes, I am going to get a plan together and take some photos .. I will get back to this thread a bit later. If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8288 Last year I had a gas leak at my house. 3 days later, I have about 1 sqm of my exposed aggregate paving broken up. I am not sure how to go about getting it repaired… 0 10403 |
