Browse Forums Landscape & Garden Design 1 Dec 05, 2011 7:36 pm I am building a 600mm high retaining wall with Tasman Blocks. Going by the Selkirk instructions I am digging a 200mm trench, compacting it then filling with 150mm of crushed rock and then compacting that. Because of previous excavation done by the builder part of my trench is already lower than the 200mm I am going to remove. How should I build it up to the correct level? A) Add dirt and compact. B) Add extra crushed rock C) Dig out the rest of trench to the same depth. (don't really want to do that.) Re: Retaining wall Foundation 2Dec 05, 2011 8:18 pm Add extra crushed rock compacting in 150mm layers until you get to the correct height. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Retaining wall Foundation 3Dec 06, 2011 8:15 pm bashworth Add extra crushed rock compacting in 150mm layers until you get to the correct height. Thanks Bashworth, I'll follow your advice. Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5179 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16140 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6901 |
