Browse Forums Landscape & Garden Design 1 Dec 02, 2011 7:22 pm Im wanting to grow star jasmine in a pot. I know that generally the larger the pot, the larger the plant. However as space is limited, I want to keep the width of the pot to 20cm. I'm going to use the jasmine as a creeper along the fence so I was wondering whether it would be more beneficial to buy a pot that is 20x80cm for plant growth or whether a 20x20cm would suffice? I'm not sure whether the extra length would make a difference or not? Thank you x Custom European Cabinets - Melbourne Kitchen Specialist PM for business details as website currently being updated! Our Crazy Owner Builder Journey! Re: What size pot is best? 2Dec 02, 2011 7:29 pm You’ll need all the post size you can get Bam, the bigger the root area the healthier the plant. Make sure you use a good potting mix when you pot out and feed regularly. As the plant grows, you’ll need to keep the water up to it, so water often. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com What size pot is best? 4Dec 02, 2011 9:06 pm Half a wine barrel. Fill with 50% cert organic potting mix and 50% coir/coco peat. That is going to be a huge amount of foliage to keep hydrated when it gets going. A tiny pot won't cut it unless you can leave the hose running all day in summer. What size pot is best? 5Dec 02, 2011 9:21 pm If price is a concern, look to using a plastic rubbish bin. Wrap it in some of that screening stuff or plastic prime it (available at automotive shops) and texture coat it. Drill holes about 10cm up the side rather than in the bottom. Fill the base with gravel. Re: What size pot is best? 6Dec 05, 2011 12:11 pm Thanks sO much Fu! Still on the hunt for decent pots but if I can't fnd the size I'll look in to something plastic Should I put gravel in the bottom regardless of the type of pot? Custom European Cabinets - Melbourne Kitchen Specialist PM for business details as website currently being updated! Our Crazy Owner Builder Journey! Re: What size pot is best? 7Dec 05, 2011 4:52 pm I'm at the green shed Is length by width more important than the height of the pot? Can't find a bin that will fit the size but there's a self watering trough that is 20x60cm. Bought some cour mulch and soil Custom European Cabinets - Melbourne Kitchen Specialist PM for business details as website currently being updated! Our Crazy Owner Builder Journey! Re: What size pot is best? 8Dec 06, 2011 10:57 am You want to get the tallest widest pot that will fit the space you have 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: What size pot is best? 9Dec 11, 2011 6:51 pm Re: What size pot is best? 11Dec 11, 2011 11:27 pm These things are used by many that you will see on the telly. Drill some holes in them and away you go. Hello I'm remodeling my kitchen and evaluating ideas. We are in the last stages of drawing and I am now considering putting a pot filler tap in above the hob. Has anyone… 0 1373 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7497 All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3664 |
