Browse Forums Landscape & Garden Design 1 Nov 20, 2011 9:57 am Hi all, Hopefully a very easy question... I'm in the process of setting up automated irrigation and have/am getting all of the bits and pieces I need. However, I'm at a loss to find a single connection piece because I'm not sure what it's called - my setup will be a solenoid, to a disc filter, to a pressure reduction valve and then on towards drip irrigation via 19mm LDPE. The solenoid has a threaded 25mm female output, the disc filter has both a 20mm male input/output and the PRV has a 20mm female input with 20mm male output. So far so good... What I am getting is a 25mm-20mm bush (to connect the solenoid to the disc filter), I believe I can just connect the filter to the PRV without any additional connection piece (correct me if I'm wrong), but I'm unsure how to connect the PRV to my 19mm poly. I've found male thread/poly connection pieces, but not a female thread/poly connection piece. Can anyone enlighten me as to what the connection piece is called? Also, if you think my proposed setup is completely off track, let me know! Irrigation - Connection piece between PRV and LPDE? 2Nov 20, 2011 6:03 pm There is a female thread available. Any good retic shop will have one. Also use an ag fitting to couple the PRV to the 15mm poly riser at the top. You will get a better seal. Irrigation - Connection piece between PRV and LPDE? 3Nov 20, 2011 6:09 pm There is a poly (LDPE) fitting that goes from the 20mm on the Pressure reduction valve to fit the poly on. Poly barb with 20mm female thread. Irrigation - Connection piece between PRV and LPDE? 4Nov 20, 2011 6:16 pm You are best to get a nylon tap at the very head of the system. It never goes rusty or breaks. That would go before the solenoid. Make sure you have a back flow valve fitted also. That needs to go before the tap. Make sure the valve you buy is mains pressure rated. Most are not and are designed to be used as secondary valves in the system. The master valve will be the one holding mains pressure when the system is off. Re: Irrigation - Connection piece between PRV and LPDE? 5Nov 20, 2011 6:26 pm If you adding to the existing system your set up is fine. Make sure that set up is not going under turf. Re: Irrigation - Connection piece between PRV and LPDE? 7Nov 20, 2011 6:48 pm This goes at the very head of the system http://www.wetearth.com.au/Product/Prod ... ductID=173 Then this http://www.wetearth.com.au/Product/Prod ... uctID=3118 Followed by http://www.wetearth.com.au/Product/Prod ... uctID=3264 Then onto http://www.wetearth.com.au/Product/Prod ... uctID=3264 Filter http://www.wetearth.com.au/Product/Prod ... uctID=1137 and so on Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20180 Hi Brainstrust, I had a go at creating my own irrigation plan, keen to get some feedback. It will be run from one 750-800W pump, off 2* 5000L rain tanks. Each zone… 0 22758 3 48368 |
